HAL.Port.CableNotCompatPlatType
Description
A cable with unknown gauge has been inserted into a port on this platform with which it is not compatible.
Remedy
Remove the incompatible cable from the port and replace it with one that is supported on this platform.
Severity
Warning
Message Text
The %optic% cable detected in port %slotPort% is of unknown gauge and is not compatible with this platform - please remove it.
Message Parameters
Name Type
optic String
slotPort SlotPort
Applicable Platforms
